06-28-2017
09:06
12:34
DavideFitbit
06-28-2017
09:06
12:34
DavideFitbit
How do I get my Blaze clock to go to 24 Hour and not 12 Hour display on clock face??? thanks in advance 🙂
Best Answer06-28-2017 09:15
06-28-2017 09:15
Go to the Settings from your Fitbit account, and from Personal info tab, scroll down and you will see Clock format 12/24h which you can adjust. It can't be done from the mobile app, so Log in via web.
06-28-2017 09:15
06-28-2017 09:15
06-28-2017 09:21
06-28-2017 09:21
This is the type of question that the provided search bar is best to use. Hont there will be no waiting for an answer.
Best Answer06-28-2017 09:42
06-28-2017 09:42
