01-04-2017 01:42
01-04-2017 01:42
I want to turn off the heart sensor on my blaze need help but also I still want the blaze to monitor the heart rate how do I go about doing so?
Best Answer01-04-2017 06:24
01-04-2017 06:24
I'm not sure I understand. If you turn off the heart rate sensor there is no way to monitor your heart rate using your fitbit.
Best Answer01-04-2017 10:07
01-04-2017 10:07
The heart rate sensor is like a light bulb, you turn ut off and it stops putting out light.. For the Fitbit if you turn it off it stops reading your heart rate.
