03-07-2016 10:29
03-07-2016 10:29
Product: Fitbit Blaze
Mobile device: iPhone 6
Operating system: iOS
As a user, I receive calendar notifications from only 1 of the 2 accounts I would like to receive them from.
I am currently only receiving notifications from my personal email account. What app does the Blaze pull calendar info from? Apple Mail? iOS Calendar App?
How do I configure my notification and app settings to receive calendar notifications from both accounts?
03-07-2016 11:19 - edited 03-07-2016 11:35
@tokenflip A bit more information regarding calender notifications:
Your tracker will show calendar events and any information sent from your calendar app to your mobile device. Note that if your calendar app does not send notifications to your mobile device, you won’t receive notifications on your tracker.
If you have an iOS device, your Blaze shows notifications from all calendars synced to the default iOS Calendar app. If you have a third-party calendar app that is not synced to your default app, you won’t see notifications from that app.
Also worth noting is that you'll receive one type of alert at a time, from one specific account/app.
04-04-2016 06:17
04-04-2016 06:17
how do you set it up
Best Answer04-09-2016 20:17
04-09-2016 20:17
@sknight wrote:how do you set it up
Hey @sknight did you get calender to work?
As for setting it up this might depend on the phone. With Android go into the calendar settings set notifications to popup. Now choose the calendar in the app.
I believe you enable it in the notification panel on iOS
