I am an HR owner, but, want to upgrade to a HR 2. I also like the classy look of the Blaze. However, the Blaze looks big for exercising (compared to the HR) so I was thinking of getting both HR2 for exercise and Blaze for work/formal. I am concerned if I use the Blaze to exercise it will catch on stuff, or get beaten up. I am not an abusive user, but, hitting the Fitbit on the arm of a treadmill, or getting it smacked when I am playing soccer, is a concern. Any thoughts would be appreciated.
Best AnswerBased on the title of your post and the actual post, I am not sure what your question is.
The standard Android or iOS calendar has a notification feature. If enabled, the Blaze will get that notification when the phone does.
Best Answer@ Patrons is correct @danfry69 the calendar pushed its notification, the app just seems it on. So how often would be determined by your calendar setting.
