01-30-2017
06:57
16:46
DavideFitbit
01-30-2017
06:57
16:46
DavideFitbit
I go to today on tracker and it's already told me steps etc. That I could not have done yet. Also not sure how to connect to calories burned
Best Answer01-31-2017 04:44
01-31-2017 04:44
Hi there @Bettybooper7. Welcome to the Fitbit Community Forums! 🙂
I'd like to know how many steps you see in the morning? If you wear your tracker to sleep, it's normal that your tracker records some steps and this is for when you move your arms while you're sleeping or when you wake up by moving around without really walking, some steps might be registered but it shouldn't be a big amount. Is that the case?
Also, on your Blaze, go to the Today section, tap on it and it will display the rest of the stats where you can scroll down until you find the Calories burned.
I'll be waiting for your reply.
