04-17-2016 13:56
04-17-2016 13:56
Can someone please tell me how/where I enter the activity of bowling for 2.5 hours? I am new and just bought the blaze. Thanks!
04-18-2016 04:12
04-18-2016 04:12
It's great to see you around @lpisarski. You can manually log an activity by doing the following from your Android Fitbit app:
1. Tap the exercise tile.
2. Tap the timer in the top right corner; this will take you to the Mobile Run screen.
3. Tap "Log" at the top of the screen.
4. Log your activity.
Let me know if you need anything else. ![]()
Best Answer01-26-2017 06:26
01-26-2017 06:26
I have an iOS 7 and I bowl 3 strings a week . There is no place to log it as bowling is not an option ?
05-23-2018 22:22
05-23-2018 22:22
While you can add a custom activity, seeing all of the activities listed in the FitBit activity list, I think that Bowling could be added to the activity list.
12-27-2018 16:40
12-27-2018 16:40
How does it aporoximate my calorie burn for bowling if its not listed as an option?
Best Answer12-27-2018 20:53
12-27-2018 20:53
If not listed use workout Mode. It will track it. after it sync you can rename it. Might have to setup a custom Activity
Wendy | CA | Moto G6 Android
Best Answer01-22-2020 10:43
01-22-2020 10:43
How do you set this up on an iPhone?
Best Answer03-27-2023 18:14
03-27-2023 18:14
Doesn't work for my versa 3. Do you mean log it as a run? My Samsung watch 4 has bowling. Since I use both I'll log it there.
03-27-2023 18:14
I wonder why it says jogger by my name. Weird
