How would I records my steps and calories burned for a water class?
How would I records my steps and calories burned for a water class since I cannot wear the fitbit in the pool?
1 REPLY 1
While you won't get any steps from it, you can log your water exercises manually at https://www.fitbit.com/activities or under the exercise tile in any app. I know there's already an alternative called water aerobics.
You enter the time you've spent doing your exercise and based on your stats it will give you an estimate of your calorie burns (or you can enter calories burned yourself if you know what you burned).
Try again. Fail again. Fail better.
