Is there any known compatability issues between the Honor 6plus and the fitbit blaze?
The fitbit and phone sync, however connected GPS does not work (fitbit says "Check fitbit app"). Notifications also does not work, yet I can control my music fine
Best AnswerA search, org Ed with your phone say the GPS doesn't work? Or go to the fitbit page of known issues.
07:48
09:36
09-15-2016
07:48
09:36
Hey there @Sommie99, good to see you in the Community!
There are not any compatibility problems at the moment that I know of. I would recommend making sure that the location services option is enabled on your phone for the GPS to work good and connect to the Blaze.
Let us know if it's still not working and if you get any other error message by any chance.
05:09
09:36
09-22-2016
05:09
09:36
Thanks for the information @Sommie99. If this feature is not working yet, I recommend following the steps provided in the My Blaze GPS is not working post. Also, you can this post where our friend @bcalvanese is providing really good steps to make your tracker more accurate.
Let me know the outcome. ![]()
