Husband's blaze suddenly not holding charge
Since the latest update, my husband's blaze is going completely flat within 8 hours of it being fully charged in the morning. Is this to do with the update? Will there be a fix put in place? Has anyone else had a similar issue?
2 REPLIES 2
I'm having exact same problem.  Mine is less than a month old...i happen to notice it updated 3 nights ago and now my Blaze won't hold charge for more than a day....i called and they're sending a replacement due to "battery defect"....
This seems too coincidental...its something with the software i think.
Hey @SamMoore8 and @TDfW it's great to welcome you.
If you are having inconveniences with your Blaze battery life, I recommend following the instructions provided in this post. After these steps, test your trackers.
Let me know the outcome. Woman Happy
