05-30-2016 15:44
05-30-2016 15:44
Best Answer05-31-2016 07:01
05-31-2016 07:01
Try restarting your Blaze with the steps below.
Best Answer05-31-2016 16:24
05-31-2016 16:24
@Illyjayvee if a restart or playing with fit doesn't fix the problem then rest assured, other people have seen the same problem and its a known issue. I like to say Fitbit is good for the 23 hours a day when I'm not working out! (Fitbit seems fine at resting heart rate, but accuracy during exercise is only ok if I settle for 'averages')
Best Answer06-06-2016 09:07
06-06-2016 09:07
Hello @Illyjayvee welcome to the Fitbit Community! 🙂 Your heart rate may be affected by any a number of factors at any given moment. Movement, temperature, humidity, stress level, physical body position, caffeine intake, and medication use are just a few things that can affect your heart rate. You can find some tips on how to improve the accuracy of your heart rate readings on this article.
@SunsetRunner and @bbarrera thanks for stopping by! 🙂
Let me know if this helps! 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
