03-07-2016 12:00
03-07-2016 12:00
Hi gang, just got finished running a 5k on the treadmill. I selected the exercise treadmill option before I started, and hit the stop button just after I finished. The treadmill itself recorded three miles run in 24 minutes, but the Blaze only recorded 1.7 miles. Anyone know why? This isn't a deal-breaker or anything...I really like the watch, but that's a pretty big disparity.
02-26-2022 15:43
02-26-2022 15:43
I do not believe that my fibit sense is calculating distance when I am walking on the treadmill. I just finished a session where I had the treadmill set at 3.0 mph. I walked for 40:02 minutes and the treadmill said I walked 2.00 miles. My fitbit sense recorded 4072 steps. My stride length for walking is set to 36" and I have set automatically turned off. If fitbit calculates distance as steps x stride length then the distance should be (4072 x 36"/12")/5280 ft/mile = 2.31 miles. The fitbit sense only recorded a distance of 1.34 miles! I have tried changing the stride length to other values and it makes no difference - stride length seems to be ignored when I am walking on the treadmill.
If I do a regular walk outside, the fitbit does seem to accurately measure distance but it is using gps for distance - no caluclating it.
02-27-2022 09:08
02-27-2022 09:08
02-27-2022 11:26
02-27-2022 11:26
I had selected treadmill for the exercise. I do not use any of the auto selection - I always select treadmill or walk explicitly. Like I said in my post the mileage does not compute correctly no matter what I put in for the stride length even though the number of steps is appropriate for the distance showing on my treadmill.
09-10-2022 16:47
09-10-2022 16:47
I think it’s kind of ridiculous that Fitbit has had this issue since 2016 and it’s still a problem. I have the Versa 3 and I run into this problem still to this day in September 2022. You’d think the newer devices or software would improve the issue. They should at least make a way to edit the distance after the run. The part about people holding the hand rails is kind of silly. I see people checking their heart rate on the handrails for a few seconds but nobody exclusively holds the hand rails that actually makes it really hard to run.
