01-07-2016 09:33
01-07-2016 09:33
Are there any photos with Blaze and Surge side by side or Blaze and Apple Watch side by side? I am just trying to picture how big it will look on my wrist. I currently have the Surge and would love to get a color screen with calendar notification.
Best Answer02-23-2016 12:25
02-23-2016 12:25
I thought it comes out in March. How did you get it early?
Best Answer02-23-2016 12:28
02-23-2016 12:28
Fitbit has started shipping the preorders - these people did overnight shipping.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Best Answer02-23-2016 20:52
02-23-2016 20:52
Best Answer02-24-2016 11:20 - edited 02-25-2016 12:57
Technically, the Blaze has a bigger screen, but is shorter. The super-flexible interchangable bands make it seem smaller! It's really the best of both worlds- nice display and comfortable fit.
Best Answer02-24-2016 17:36
02-24-2016 17:36
@SunsetRunner wrote:
When multiple trackers are linked to the account, it's as easy as just wearing the tracker you wish to use. The magic happens automatically.
Of course best to wear / use one device at a time.
Is the blaze supported by the multiple tracker ability?
Best Answer02-25-2016 12:21
02-25-2016 12:21
Of course. ![]()
Best Answer03-14-2016 21:44
03-14-2016 21:44
I just switched. It may look big but definitely wears more comfortably than the Surge, especially for my small wrist. The bulky band of Surge makes wearing long sleeves difficult.
Best Answer03-15-2016 02:02
03-15-2016 02:02
How do o post a picture? I've one to post on this thread.
Best Answer03-15-2016 02:10
03-15-2016 02:10
First you want to go to the bottom of the page and click Full. This will give you the desktop verson. Now you will see the picture icon above the entry box.
03-15-2016 02:28
03-15-2016 02:28
Here's one I did earlier.
May Blaze compared to a Surge in sale in Currys.
12-05-2017 10:10
12-05-2017 10:10
Im buying a serge online, are they easy to reset? Do you think the are accurate in tracking gym classes and walking etc. Never owned a fitbit.
Best Answer12-05-2017 16:37
12-05-2017 16:37
Is this a used Siege, everything gets setup when it gets connected to your Fitbit account.
The surge is thicker and does not have a replaceable band, however a third party sells a repair kit on Amazon.
With walking it is nice to have gps built in and depending on how well the battery has been treated you could get up to 8 hours of gps.
As for gym it is as good as the blaze, which personally I would get if money is available.. If your buying used, do you really know the condition? There will be no warranty.
