09-19-2019 19:28
09-19-2019 19:28
I have had multiple issues with my Blaze, warranty replacement 3 separate times, latest doesn't hold charge for more than 8 hours. Not a very useful watch if it cant even go a full day. I have spoken with support on multiple occasions and the only remedy is to keep replacing them. I would like to upgrade to a better product due to the lemon of a design. Having already done the upgrade from the Charge 2 after it broke 6 months in, I am $249 deep into my current Blaze(3rd). I received an email today to upgrade to a Versa 2 with a whopping $30 discount. looking through these forums it is apparent that the Blaze is a faulty design, why else would it be discontinued so quickly. When is Fitbit going to do the right thing and buyback or give full credit towards a better product?
09-19-2019 21:24
09-19-2019 21:24
I have several devices and I do not have the problems you do
How do you charge it? Best on the computer and a USB port
See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
Having it replaced 3 times suggests something is wrong on your end. Sorry
Wendy | CA | Moto G6 Android
09-20-2019 02:26
09-20-2019 02:26
I would love to see this as well. I've had issue after issue. It's never been a great tracker. It's done what I've required it to do but it's always had faults. It has issues tracking my sleep. Sometimes doesnt charge. Doesnt hold a good charge.
Best Answer09-21-2019 19:44
09-21-2019 19:44
Same problem with my blaze an they did the same thing. $30 discount and for a month only. My husband had an alta so I've been using it but its not what i want . Your right Fitbit should step up and do the right thing. Ive been a member for 6 years with multiple devices.
Will probably to a garmin or apple
Planned obsolescence?
