08-02-2016 13:24
08-02-2016 13:24
Best Answer08-02-2016 13:53
08-02-2016 13:53
Hello @ALEXIS81 have you tried a shutdown, found in the settings menu?
I would also do an add tracker as a replacement unit.
Best Answer08-02-2016 14:01
08-02-2016 14:01
If the heart rate is set to "off" under settings, then the Zone watchface will have a black background.
The Pop watchface has numbers cut off at the bottom, by "design" (I would fire whoever designed that one)
Enable the heart rate, your zone face should work OK
Best Answer08-02-2016 19:40
08-02-2016 19:40
Best Answer08-05-2016 23:24
08-05-2016 23:24
08-05-2016 23:24
Best Answer08-06-2016 01:57
08-06-2016 01:57
Best Answer08-06-2016 16:23
08-06-2016 16:23
