06-16-2017
04:48
19:58
DavideFitbit
06-16-2017
04:48
19:58
DavideFitbit
Hi hope that some can i have been charging my Fitbit Blaze pebble for 6.5 hours but on my Fitbit app it's saying that the battery is empty .I was wondering if it can still be charge even when it's empty or do I have to buy another Fitbit Blaze pebble
cats64
Moderator edit: subject update for clarity
Best Answer06-16-2017 04:58
06-16-2017 04:58
The information on the app may be out of date as it only shows the battery level as it was when it last synced.
If you open the charging cradle and close it again it should show a battery level on the Blaze and, after 6 hours, it should be full.
If it's not, or the battery status doesn't show, then it may not be charging and I would try a different USB power source such as a wall charger used for your phone.
06-16-2017 05:43
06-16-2017 05:43
