01-24-2019
02:40
12:17
FerdinandFitbit
01-24-2019
02:40
12:17
FerdinandFitbit
As I can't wear my Fitbit Blaze in the pool. How do I input my daily swims and pool aerobic work outs?
Moderator edit: Updated title for clarity
12:17
09:23
01-24-2019
12:17
09:23
Hi there @BonsaiDan, welcome to the Fitbit Community Forums! 🙂
I'd like to help you out with this.
You can definitely keep track of these activities by logging them manually. For this, while you're on the Fitbit app, tap on the Exercise tile and then, tap on the stop watch at the top right corner of the screen. Here, you have two tabs, one that says track which you can use to tracka walk, a run or a hike from your phone and the other one says Log. On this second one, simply type the word Swim or Water Aerobics and you just need to fill in with the required information. Once you've done this, the activity should show up on your activity log.
Hope this helps. Let me know if you need more help!
12:17
09:23
01-24-2019
12:17
09:23
Best Answer01-27-2019 09:21
01-27-2019 09:21
