05-14-2017
13:43
11:05
05-14-2017
13:43
11:05
Hi there @Daniella1987. Good to see you in the Community Forums! 🙂
I'm sorry you're having problems with your tracker resetting itself. Have you tried to manually restart it to see if that makes a difference? If not, You can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot. Also, if that doesn't help, setting up the tracker as a new device could do the trick. For this, go to the Account section at the top right corner on the Fitbit app and select the option that says "Set up a new device". Follow the on-screen instructions and once you're done, your tracker should be syncing without a problem.
Let us know if you still need more help after doing that. We'll be happy to help you out!
