07-07-2016 09:49
07-07-2016 09:49
Best Answer07-07-2016 14:03 - edited 07-07-2016 14:04
@Blackfox_hair we have a long list here, lets start with the display.
Is quickview turned on? Swipe over to settings, tap, scroll down to Quickview.
Oh lets pause a minute, your blaze has a touch screen, like your phone, so when tapping lets tap the way you would on the phone. It is more like a gentle touch and release. If your finger moves during this touch/tap then the tap will not work. Pressing any button will also turn the display on.
Quickview requires the arm to be brought up into a close to horazontal position, then rotated so the watch is facing you. Once the movement is understood, do a little experimenting it works quite well.
As for alarms, touching, appose to tapping, or lifting for quickview to activate will work. Yes the alarm does not turn the display on, Fitbits thinking is that it would be better to wait until the user would like to view it.
Lets look at the treadmill and miles.
Your tracker is unable to measure miles and must calculate them. So lets look at the Steps tje Fotbit recorded, do they look correct? Remember that holding on may cause syeps to be missed and your will be low. The Fitbit is looking for the correct arm movevements. Once the step count is confirmed the stride will need to be setup. Also changing the speed of the treamill will cjange your stride. By taking the distamce the treadmill reports and the steps the tracker reports, going to a site like this, the stride can be rasily figured.
Yes manually added steps do not show in challanges, see the FAQ.
As for the data showing up on the dashboard, check the Device settings to see when the tracker last synced. If you feel it recently did then log out/in.
As for notifacations check this Help guide.
Yes i find the interactive help guide along with the Blaze manual very helpful.
The link to help may be found below, and the manual can be found by clicking on the picture of your tracker.
Keep in touch
08-18-2016
07:03
09:54
08-18-2016
07:03
09:54
Hi there @Blackfox_hair. Good to see you in the Community!
Thank you so much @Rich_Laue for providing such a complete response.
@Blackfox_hair, If you continue to have issues with your tracker, I'd recommend getting in touch with the Support Team and they will be happy to help you out with this!
