07-17-2016
05:02
18:57
DavideFitbit
07-17-2016
05:02
18:57
DavideFitbit
I need help! I've been using my Fitbit Blaze for about 10 days and have been logging all my food. I'm usually under target by a few hundred calories and set it to "medium." So I'm supposed to lose at least 1/2-1 pound a week, right? I haven't really seen a drop in weight. I'm getting discouraged. Any tips?
Best Answer07-17-2016 05:21
07-17-2016 05:21
@XinaRamIt's not magic.....have you tried moving more?
Are you weighing yourself daily and at the same time of day?
Keep at it.
If you put less in and move more, you cannot fail to lose some weight.
Make sure you correctly set all your measurements within your profile.
Set the food plan to be based on a sedentary lifestyle (if applicable) as the calorie targets are calculated differently during the day.
Be mindful of the fact that if your activities are they type that build muscle, you won't necessarily see a drop in weight.
Best Answer07-17-2016 06:51
07-17-2016 06:51
07-17-2016 07:13 - edited 07-18-2016 10:31
A normal person will have up to 5 pound fluctuation throughout the day.
16 ounces of Water weighs 1 pound.
Have you used the restroom lately? This will add excess weight, that meal you just ate also will add to the scale.
My suggestion is to connect your Fitbit account to trendweight.. Trend weight will take your daily readings then look at uh general trend in weight ignoring these daily fluctuations
07-17-2016 07:15
07-17-2016 07:15
07-17-2016 07:21
07-17-2016 07:21
07-19-2016 04:15
07-19-2016 04:15
I am certainly no health "expert"... but here is something you can try... I average @ 17-18K steps per day and have for more than a year... I frequently hit plateaus and have the need to "change things up a bit" to reset (confuse) my metabolic rate. Have you tried the (relatively) new feature in the FB app. that tracks 250+ steps per hour?... I find if I try to meet those goals at least 3X per week, I spread my excercise out throughout the day and I will lose weight again. Be sure to use your "drill down" features in the app... Tap "BPM" > Tap "A particular day" > (Watch how many hours/day you are in the "Fat burn state"...)
Hope this helps... I KNOW it can be frustrating... but 10-days really isn't long enough to obtain an accurate opinion of whether "things" are working or not... Good Luck!!
07-17-2016 05:21
07-17-2016 05:21
Keep at it.
Best Answer07-17-2016 06:41
07-17-2016 06:41
07-17-2016 06:51
07-17-2016 07:02
07-17-2016 07:02
Best Answer07-17-2016 07:13 - edited 07-18-2016 10:31
07-17-2016 07:15
07-17-2016 07:15
07-17-2016 07:17
07-17-2016 07:17
07-17-2016 07:17
07-17-2016 07:17
Best Answer07-17-2016 07:21
07-17-2016 07:21
07-17-2016 09:10
07-17-2016 09:10
Best Answer07-17-2016 11:14 - edited 07-18-2016 10:32
Slow and steady wins the race, look at all the people that have gained the weight back on the biggest loser.
Ideally this is a change in lifestyle, a crash diet is a temporary fix.
Best Answer07-19-2016 04:15
07-19-2016 04:15
07-19-2016 05:12
07-19-2016 05:12
Best Answer07-19-2016 06:20
07-19-2016 06:20
Best Answer07-19-2016 06:26
07-19-2016 06:26
Best Answer07-19-2016 06:27
07-19-2016 06:27
