07-29-2016 11:44
07-29-2016 11:44
07-29-2016 12:02
07-29-2016 12:02
07-29-2016 14:53
07-29-2016 14:53
Blaze calorie burn estimate is based on heart rate, so first step is to review this wearing tips:
Optical HRM can be hit or miss, some people are more "hit" (it works well) and others are more miss. It also depends on what you are doing, optical HRM doesn't work as well when you are bending wrists like with weight lifting or trx or crossfit. Try out some of the wearing tips and see if that helps.
07-29-2016 15:15
07-29-2016 15:15
07-29-2016 15:33
07-29-2016 15:33
Reset is next step. Mine works well, except when weight lifting or cycling, and then its wacky.
I'd call support and see if they have anything to add. Blaze HRM is pretty good at resting heart rate and walking, so its odd yours is so off. Maybe a bad unit?
07-29-2016 16:53
07-29-2016 16:53
07-29-2016 18:03
07-29-2016 18:03
I haven't had good luck with weights, trx, and biking.
