07-09-2018
16:34
08:09
FerdinandFitbit
07-09-2018
16:34
08:09
FerdinandFitbit
My battery life is less and the battery on my app is a red perimeter with a vertical line
Best Answer07-10-2018 08:08
07-10-2018 08:08
Hi there @Shankster69. Good to see you in the Fitbit Community Forums! 🙂
If I'm not wrong, you're saying that your tracker's battery is low and that on the app, you're seeing also that the battery is low, is that correct?
If so, are you having problems getting your Blaze to charge? What is exactly going on? Have you tried to put it to charge? What happens when you do this?
If you could please provide with as much detail as possible of what is happening, I'll appreciate it a lot and I'll be happy to help you out!
Best Answer07-10-2018 17:35
07-10-2018 17:35
Hi I charged my Blaze today and it lasted 2hrs I might have to buy a new battery
