12-19-2018
10:52
15:53
FerdinandFitbit
12-19-2018
10:52
15:53
FerdinandFitbit
Good afternoon,
This started happening recently, but after workouts my blaze's right button is triggering by itself. Every 10 or so seconds the button seems to get "stuck" and it keeps vibrating. I checked for debris and there doesn't seem to be any. I am removing it after workouts and clean it when I get home, but it isn't possible that it has water damege due to sweat right? It isn't even a year old.
Moderator edit: Updated title for clarity
Welcome to the Fitbit Community Forums @RJoenck! 🙂
I'm very sorry to hear that the button on your Fitbit Blaze seems not to be working properly. Thanks for all you've tried to get your tracker to work. I'll be happy to help you out with this!
Even if it seems not to be working fine all the time, have you tried to restart your tracker? If not, You can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot.
Let me know how it goes!
Hi Ferdinand,
Unfortunately, I have tried it as well even when I tried shutting it down it will come back on a few moments later without me pressing anything.
Best AnswerI have the same issue. It started yesterday. I have restarted, cleaned, and removed it from the bezel. The button works when I push it, and when I don't.
