Make a bigger Blaze battery icon
I would like to see a bigger and more accurate icon to show the batteries level.
Why does my battery life sometimes seem to only last a day or two? It seems to last longer after I sync my tracker.
I would like to know why I have reboot or restart my Blaze to get it to sync through my PC?
2 REPLIES 2
@jameskevin as for the larger battery icon, this is not availible.
As for syncing throught the PC, do you also sync through a phone? If so turn the phomes bluetooth off, or move the phone at least 30 feet away before trying to sync through the pc.
BTW it is not necessary to sync through two devices, a sync only takes the data from the ttacker snd drops it on the Fitbit server. It also will shorten the battery life.
A warm welcome to the Forums @jameskevin and @Rich_Laue thanks for stopping by.
Regarding the battery level icon, I recommend taking a look at the Fitbit Blaze Battery Level Screen request, vote for it and leave your comment. If you are having problems with your battery life and syncing your Blaze, follow the instructions provided in this post for the battery and for syncing follow the instructions provided in the Having trouble syncing? post.
I hope this helps, let me know the outcome. Woman Happy
