Map/GPS issue
For my last 3 runs the map on the Blaze has been incorrect.  For the first run that was wrong, it showed the map of the run prior.  For the second run it stopped after 1.78 miles and for the third run it stopped after 1.7 miles.  It does continue to calculate time, distance and steps though on the exercise.  Not sure why the map just seems to cut out.
1 REPLY 1
Hi there @birdman805. Great to see you in the Community Forums! 🙂
I'm sorry you're having problems with the maps for your runs not appearing correctly. Actually, this happened to someone else and it seems to have sorted itself after a while. For some of the instructions that I provided in that situation, click here.
Let me know if you need more help with this!
Ferdin | Community Moderator, Fitbit
