02-16-2016 01:02
02-16-2016 01:02
Hi everyone!
I'm new to the Fitbit community!
I've been waiting for a 24/7 activity tracker but have been restraining myself from Surge due to battery life with GPS. Looks like Blaze might be my first Fitbit! 🙂
I'm planning to join a race that lasts 46 hours (yes, two days nonstop) and having a mobile phone is a must during these sort of races and I'm always commuting and running with my phone anway.
So if I understood Blaze correctly, the battery life should be sufficient to last 5 days but I just wanted to check the battery life for Blaze if the GPS is always on during an ultrarunning, nonstop, multiday race?
I seriously doubt it'll still be 5 days. I might be wrong...
Can someone please help clarify?
Thank you!
02-16-2016 01:16
02-16-2016 01:16
Best Answer02-16-2016 01:39
02-16-2016 01:39
Here's my solution, I put my phone (Samsung S5) on flight mode but leave the GPS running.
My phone's GPS do not require mobile data to work when I've previously logged my runs. This drastically improves my phone's battery life. So it's been done before 😉
There are many other solutions anyway. I've got power banks, spare removable phone battery, phone swaps during checkpoints...
So my concern is still on Blaze 🙂
Best Answer02-16-2016 01:42
02-16-2016 01:42
Best Answer02-16-2016 03:58
02-16-2016 03:58
@UltrarunnerJonL wrote:Here's my solution, I put my phone (Samsung S5) on flight mode but leave the GPS running.
Flight Mode => Bluetooth OFF GPS ON ==> Blaze assisted GPS OFF
Flight Mode ==> Bluetooth ON GPS ON ==> Blaze assisted GPS ON => Smartphone Battery DOWN
Another idea
Best Answer02-16-2016 04:44
02-16-2016 04:44
Another idea
Not sure about your phone but mine allows me to use bluetooth and GPS even with flight mode on.
Based on my experience running outdoors, the main reason the phone battery drains quickly is mobile data, followed by network reception search. My flight mode allows me to specifically choose which to activate/deactivate.
I've not mentioned the ultra-power-saving mode that will last a good 24 hours with BT and GPS.
A power bank would be my simple solution - trust me, that's not that heavy considering the 2L of water, food, jackets, mandatory running kits in my backpack, etc...
So back to my initital question, if phone battery is not an issue (and it isn't for me), how long will Blaze last with GPS constantly on?
Best Answer02-16-2016 05:46
02-16-2016 05:46
02-16-2016 06:09
02-16-2016 06:09
Thanks @Julia_G!
My guess calculation is, if the average sleep time is 8 hours, that leaves Blaze with (24hrs a day - 8 hours sleep) approximately 16 hours of GPS tracking a day.
If Fitbit claims that it will last 5 days, maybe the continuous GPS battery life would be somewhere in the region of 5 x 16 hours = 80 hours.
@fitbit are you able to clarify how was the 5-day battery life calculated? What was the average 5-day usage based on?
02-16-2016 07:28
02-16-2016 07:28
@UltrarunnerJonL It sounds like you're preparing to embark on an insane journey- best of luck!
The 5 days is the amount of time Blaze should last with normal usage (moderate use of Quick View, a few GPS activities, exercise mode usage, etc.). I've gotten this question a few times, but I'm not sure how long it'd last. Let me poke the right people again ![]()
Best Answer02-16-2016 07:35
02-16-2016 07:35
@EmersonFitbit wrote:@UltrarunnerJonL It sounds like you're preparing to embark on an insane journey- best of luck!
Thanks @EmersonFitbit It's just something I do occasionally on weekends but only with my phone previously (without heartrate). I could have bought a bluetooth HR strap but I'm glad Fitbit came up with something that can cater to my needs and monitor my heartrate 24/7.
Only thing I need to clarify is Fitbit's definition of "normal usage" or "a few GPS activities" as this might be the deal breaker for me. 5 days is just too vague!
Please can you give me a detailed breakdown? i.e. how many total hours of maximum usage with GPS.
Thanks!
Best Answer02-17-2016 08:50
02-17-2016 08:50
Another idea
I think you have an iPhone. Its simple, turn on Airplane Mode and then turn on Bluetooth. You could also turn on Low Power mode.
This article has very good information about conserving phone battery life, its written about iPhone but applies to other phones:
http://www.adventurealan.com/iphone-gps-map-backpacking/
You can really stretch out battery life on most modern smartphones.
Best Answer02-19-2016 05:22
02-19-2016 05:22
Did you found out @EmersonFitbit ? ![]()
Best Answer02-19-2016 23:43
02-19-2016 23:43
