04-12-2017 12:05
04-12-2017 12:05
Hi All
I have had a Blaze since November which has always registered the mileage I do on my bike until recently on either my iPad or iPhone. I have checked the settings on both which shows gps is on, but still not able to show the mileage. Can anyone assist?
Many thanks
John
04-12-2017 12:08
04-12-2017 12:08
Ate you using the Multitract Bike mode, and does the Blaze show being connected? Or are you depending on the tracker to detect yoir bike ride?
04-12-2017 12:18
04-12-2017 12:18
04-12-2017 12:32
04-12-2017 12:32
You can have up to seven out if I believe 18 events, all you need to do is customize your list. Http://help.fitbit.com/?q=multisport
Yes this bike mode needs to be manually started for GPS and the map to show.
