05-14-2016 09:12
05-14-2016 09:12
05-14-2016 09:25
05-14-2016 09:25
First question where you using the Mobile GPS tracking, and started out on the phone, or did you use the connected GPS and started your tracking with the Blaze.
You say you restarted the phone, but have you reset off the Blaze? Sometimes shutting the Blaze diwn through its settings menu, then turning on is enough.
Best Answer05-14-2016 09:39
05-14-2016 09:39
Best Answer05-14-2016 10:06
05-14-2016 10:06
So the mobile track with its map synced find, the problem is getting the data on the Blaze to Fitbit.
This is simply a case of the Blaze not syncing, so let's do a hard reset, or go to the Blaze settings menu, and perform a Shutdown.
Try tuning the phones BT off/on.
If this doesn't work then restart the phone, or shut it completly off.
Keep me informed.
Best Answer05-15-2016 11:23
05-15-2016 11:23
