10-21-2016 19:37
10-21-2016 19:37
10-22-2016 08:33
10-22-2016 08:33
Is the device you are trying to sync to a supported device?
Android: https://www.fitbit.com/content/assets/onezip/images/devices/Fitbit_SupportedDevices_Android.pdf
Best Answer10-27-2016 04:43
10-27-2016 04:43
I have the same problem. I have a Google Nexus 5X
The app is syncing steps etc but notifications or music control isn't working when paired in "bluetooth classic" mode
Best Answer10-27-2016 13:09
10-27-2016 13:09
Best Answer01-07-2017 05:49
01-07-2017 05:49
Ive got the same problem, did you get an answer for this?
Best Answer01-07-2017 09:14
01-07-2017 09:14
Fixed ? no. It is very plain broken
. Occasionally the Blaze music controls work and occasionally I get notifications from the app on the phone, but usually they are 3-4 hours after the actual events.
The bluetooth notification and media integration is very poor (at least on android, not tried iOS). The fact that it is intermittant suggests it had little testing (my Phone is a relatively new Google Nexus 5X)
