03-09-2016 19:04
03-09-2016 19:04
03-09-2016 19:35
03-09-2016 19:35
03-10-2016
12:29
05:46
03-10-2016
12:29
05:46
Hey hey hey @MrsDLine @VykkDraygo a warm welcome to the Community! I noticed that @VykkDraygo provided useful information. Additionally, you can turn on your phone's bluetooth only to sync. In case you have all-day sync enabled you can turn that feature off, some customers find that all-day sync causes the battery on their mobile device to drain too quickly. Your tracker syncs with the Fitbit app every time you open the app, or periodically throughout the day if you have all-day sync turned on. You can learn more about "How do Fitbit trackers sync their data?" at our help article.
Let me know how it goes!
Was this what you were looking for? Vote for it and mark it as an Accepted Solution!
03-10-2016 12:36
03-10-2016 12:36
Bluetooth on the iPhone uses very little power unless being used. I leave mine on day in and day out. Some people are **ahem** about getting 4 days on a battery where I just charge every night while sleeping and never worry. The 6S+ does have the advantage of great battery life so it may not apply to everyone.
03-13-2016 09:04 - edited 03-13-2016 09:06
Thanks for sharing your thoughts with us @SunsetRunner! Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
See you around!
02-14-2017 08:57
02-14-2017 08:57
02-14-2017 09:12
02-14-2017 09:12
@Sieberen please read the posts above for your answer.
In short the Bluetooth needs to be on for the tracker to sync. Otherwise it will work fine without the phone nearby..
03-13-2017 05:58
03-13-2017 05:58
Hi! At the risk of sounding totally dense! I have only started with my fitbit today. I have a flex2. And I usually don't have my Bluetooth switched on my phone very often; therefore will it still count steps etc with Bluetooth off please? Or do I need to switch on when I want to check the current update? Would appreciate your help please. Thanks.
03-13-2017
10:51
05:46
03-13-2017
10:51
05:46
Hi @CPMemphis! Welcome to the Fitbit Community Forums and great choice on the Flex 2! 😄
You don't need to have your bluetooth on all the time in order to have your tracker to record your activity. The bluetooth is only for syncing your tracker to your app but if you have it off, your tracker will still count your steps (notifications will not work with bluetooth off) but all other features as counting steps, distance, calories, etc., will still work and once you can enable your bluetooth on your phone, all the information will sync.
Hope this answers your question. Let me know if you need more help!
03-16-2017 12:39
03-16-2017 12:39
Great thank you so much for your help!
03-16-2017 12:59
03-16-2017 12:59
You're very welcome @CPMemphis! Anything else you may need, let us know. We'll be happy to help! 🙂
04-04-2017 08:02
04-04-2017 08:02
Are you able to use pandora on wireless headphones and still receive notifications if all linked on the same phone?
04-04-2017 08:09
04-04-2017 08:09
That depends on your phone. Most phones should be able to do so with no problem. I always have my watch connected, and it still works when connected to my car or headphones (even with GPS functionality while running).
04-04-2017
08:18
05:46
04-04-2017
08:18
05:46
Hey @New2fitness. Great to see you in the Community!
As @VykkDraygo says, that shouldn't be a problem. I am able to use my bluetooth headphones or bluetooth speaker and I'm able to control the music from my Blaze and receive notifications at the same time.
05-25-2017 00:14
05-25-2017 00:14
How many days of memory will my Flex 2 keep before I turn my Bluetooth on? It doesn't seem to sync any steps if it's been off.
05-25-2017 01:13
05-25-2017 01:13
@Cdovnh to answer your question, lets go to your user manual https://staticcs.fitbit.com/content/assets/help/manuals/manual_flex_2_en_US.pdf
7 days of detail data, and another 23 of daily totals. So sync once a week and your fine.
06-17-2017 03:48
06-17-2017 03:48
I'm jumping on this because it's the most acurate question I need answered. Does the fitbit still let you know when you've reached steps even if bluetooth off?
06-17-2017 07:26
06-17-2017 07:26
If your referring to your tracker @EilidhA you don't even need your phone with you. The tracker still gives you the celebration.
Of your reefing to the Fitbit app, then you will need to wait for the next sync and this requires Bluetooth.
11-23-2017 23:43 - edited 11-24-2017 20:28
Your Fitbit will still sync even with no bluetooth, once you go to settings then hit Forget This Device, the bluetooth will no longer connect, but you can still sync with the app just fine. Notifications are still disabled & live feeds of your fitbit are also disabled, but all data will still sync without bluetooth.
***UPDATE I was wrong with what I wrote above, I apologize for the false information. The bluetooth will automatically connect to bluetooth again after the device is forgotten. So to sync, have notifications, bluetooth is required***
11-24-2017 14:59
11-24-2017 14:59
@Sieberen see above especially @CindyFitbit's post
The answer is no you don't even need to carry a phone with you or even use the phone to sync, if you have a different way to sync
