My Blaze does not reflect accurate mileage nor heart rate
I have a couple of devices monitoring my heart rate and mileage.  Two are reflecting similar reading while the blaze is much lower than the other  devices (1.5 miles lower and heart rate about 30 bpm lower)  I never hadthat issue with the Charge 2.  Is there something that I can do to calibrate it?
1 REPLY 1
A warm welcome to the Community @tmor949! Each device has its own algorithms so, if you're using different devices they won't give you the same information even though you're walking the same distance.
You may want to learn more about how Fitbit will track your heart rate by checking What should I know about my heart rate data?
Hope this helps!
