06-05-2017
11:25
05:53
FerdinandFitbit
06-05-2017
11:25
05:53
FerdinandFitbit
My blaze will not hold a charge. Powers on when connected but as soon as i remove it, it powers off.
Tried all the solutions on the troubleshooting page but nothing worked.
Moderator edit: Clarified Subject
06-05-2017 12:20
06-05-2017 12:20
you may need a new fitbit. if you have had it for under a year you can still send it in and they will send you a replacement.
06-11-2017
05:59
07:37
06-11-2017
05:59
07:37
Hi there @Johnzor1234. Great to have you in the Community Forums! 😄
I'm glad you followed @bb-8's advise and you got in touch with the Support Team. I was able to check with them and it seems that a replacement is on its way and I hope to see you back on track soon!
Any other thing you may need, let me know and I'll be happy to help!
08-15-2017 07:54
08-15-2017 07:54
So if it's over the warranty period you have to replace? No other fixes? Can't afford a new one right now.
08-15-2017
11:26
07:37
08-15-2017
11:26
07:37
Hey there @drdlk. Good to see you in the Community! 🙂
When it comes to the limited warranty, once it's over, your tracker will not be replaced for any reason. However, based on your particular case, our Team may be able to offer a discount in the purchase of any tracker for you to be able to keep going with your healthy lifestyle using your Fitbit tracker.
What is the problem you're having? I'd like to help you out with this and see what would be your options!
08-16-2017 13:08
08-16-2017 13:08
Hi, The unit would light up when plugged into the usb but when unplugged nothing. I tried resetting 3 times and also tried to deactivate and reactivate with my IOS. Would not find the unit. Wasn't counting steps, the unit was basically dead.
08-16-2017
13:13
07:37
08-16-2017
13:13
07:37
Thanks for getting back @drdlk!
I'm sorry to hear that 😕
Have you tried by any chance plugging the tracker to a wall USB adapter directly? This could make a difference. Let me know if you're able to try and even if you're not, let me know so we can see what are the options here.
08-16-2017 13:17
08-16-2017 13:17
Will do. Since the lights are all on when plugged in what's your suggestion for a fair amount of time to charge it via your suggestion?
08-16-2017 13:19 - edited 08-16-2017 14:39
I believe I have had this Blaze less than a year but the broken screen is apparently an expected product shortcoming. Since it's a product fault, how do I go about getting it fixed by Fitbit?
08-16-2017 17:26
08-16-2017 17:26
Hi Again
i tried charging it for 4 hr from the wall but to no avail.
Dan
08-18-2017 04:17
08-18-2017 04:17
Good Morning,
Just checking to see if you were able to come up with any options.
Dan
