03-09-2016 13:25
03-09-2016 13:25
I had no problems syncing my Blaze to my Galaxy S6 phone, but I noticed that after awhile I was not getting my notifications. When I checked my bluetooth settings on my phone I saw that my Blaze was not connected so I connected it again. This continues to be an ongoing problem. I'm having to check my phone to make sure that my Blaze is connected. Today I had to reconnect it three times. Is it my phone or the Blaze that's giving me problems? I don't have this problem with any other devices that are synced with my phone.
03-09-2016 13:31
03-09-2016 13:31
I've had issues a couple of times with bluetooth, but it's always been resolved within a couple of minutes. I find that if I hard reset (hold the left button and the lower right for a few seconds) the watch it often is remedied; you should also turn off your bluetooth on your phone and then reconnect if you still have problems. After doing both of those, I typically do not have any more problems.
Best Answer03-09-2016 13:31
03-09-2016 13:31
Best Answer03-10-2016 06:16
03-10-2016 06:16
Thanks @AdamMSC. So far it's staying connected. Yay!
Best Answer03-22-2016 03:34
03-22-2016 03:34
03-22-2016 17:40
03-22-2016 17:40
Best Answer03-22-2016 22:35 - edited 03-22-2016 22:36
If it is the BTLE then the app will reconnect when doing a sync.
If it's BT Classic I haven't had a problem with it disconnecting but ocaisionally have had to unpair/repair to get the music control to work.
Best Answer03-23-2016 08:28
03-23-2016 08:28
Best Answer04-27-2016 08:17
04-27-2016 08:17
Best Answer04-28-2016 16:08
04-28-2016 16:08
Best Answer03-11-2017 17:24
03-11-2017 17:24
I am looking for an answer to that also. I have a samsung note 4 with same problem. I have hard reset blaze, tried to unpair and repair blaze to phone, and also have a zte 959 that it won't work to reconnect to that phone automatically also. This has been extremely frustrating to say the least. If I do get an answer I will pass it along. If anyone can help, please let us know. I personally believe it is a firmware issue that they need to address to get the bluetooth to automatically connect to phone. No matter if you lose it by distance, turning bluetooth off and back on, or rebooting phone, the blaze will NOT automatically re-connect to phone. BOO!
