07-18-2016 07:45
07-18-2016 07:45
07-18-2016
08:43
06:53
07-18-2016
08:43
06:53
Hi there @Liz311. Good to see you around! 🙂
I would just like to know what exactly you mean when you say that your Blaze won't stay on. Is the battery dying and it shows you a low battery notification or it's that it will show the display for a while but turn off after a few seconds and come back on when you tap it or press a button?
I'll be looking forward for your reply to know what is exactly going on.
07-18-2016 08:51
07-18-2016 08:51
01-06-2017 15:25
01-06-2017 15:25
I'm having the same issue. Can it not be resolved other than replacing?
01-06-2017 18:23
01-06-2017 18:23
Oh Gosh, that's a concern. I'm contemplating buying a Blaze in a couple of months. Other than that, how's it going, worth it?
01-06-2017 18:42 - edited 01-08-2017 01:39
01-06-2017 18:50
01-06-2017 18:50
I love it other than this issue. It was a gift from my husband. I don't like to spend on myself. I have been walking fairly regularly for over a year now and then started a new fitness challenge in November. He knew I was just using an app on my phone. The Blaze had been so much more accurate with steps, and it also monitors heart rate, so I could see how long I was staying in the "burning" window. I have contacted customer support, so I will see what happens.
01-06-2017 19:07 - edited 01-10-2017 15:28
Yes I enjoy the fitness functions and also wait until 'occasions' to spend the $
i got aria for Christmas and I love it along with all the fitbit functions
I hope it works out for you
01-09-2017
04:11
06:52
01-09-2017
04:11
06:52
Hi there @H_wittman @GetABitFit! I'm happy to see you in the Community Forums! 😄
When it comes to the Fitbit Blaze not staying on, this could be because of the QuickView feature which will make your tracker's display to turn off while you're not seeing it and whenever you turn your wrist towards you, it will light up to show what's on the screen. You might want to take a look at this post about how QuickView works.
Let me know if there's anything else I can help you with!
01-09-2017 18:29
01-09-2017 18:29
I understand the Quickview mode, and no that's not it. It's not just sleeping. It completely shuts down. And now I can't get it to even power up if it isn't connected to the charging port. I have contacted Customer support and have been advised of my options.
01-10-2017 06:47
01-10-2017 06:47
Oh, okay, I see. Thank you so much for getting back and clarifying the problem. I'm glad that the Support Team was able to help you out with this. Hope to see you back on track soon @H_wittman!
02-21-2018 16:28
02-21-2018 16:28
My Blaze is doing the same thing. It is fully charged but when I put it in the band it goes off after a few minutes.
