My Blaze won't turn on!
My blaze wont turn on even when I put it in the charger! What's going on?
36 REPLIES 36
Resetting worked! It’s charging now!! Thank you so much!
It shows that it's charged when it's in the cradle but after you take it out it doesn't come on
I tried all those steps and my blaze still will not turn on what do I do????
Iconic just did the same thing! Out of warranty 2 months!
Mines still hasn't came on I tried resetting still doesn't do anything as I said before if it's in the charger it shows it's charging but once I take it out it does nothing
I have pressed the buttons for 10 seconds, I feel the vibration, but it still won't turn on.  It's fully charged.  Any suggestions?
I have the same experience with my Fitbit Blaze and  I don't know what else to do after trying all attempts to power it on. What should I do?
It's done gove up. They just die. Fit bit sucks!
Tred using left and right down buttons but its not switching on. When i put on charge i see fitbit symbol glowing on screen
Mines does the samething
Did u let it charge for a day or two?
Problem is resolved.
Yes.  I charged it for several days.  I got it to vibrate, but the screen never turned on.
I never got anything to come up on the screen.
Yes it charge in cradle but when I take it out nothing
I haven't seen any responses to address when the Fitbit Blaze has been fully charged, yet the reset (left button and bottom right button) are pushed for 10 seconds, still gets a vibrate, but isn't fully turning on.  That's where mine is now.  I can tell it has a charge, but all the reset does is create a single vibrate.  Mine went out after spending an hour at an indoor trampoline place.  Did it overload with calculating number of floors due to the jumping and flipping?  Help.
Thank you so much!! I’ve been messing with my Blaze all day. Very frustrating!! You made my day, it worked!!
