02-15-2018 07:44
02-15-2018 07:44
My Fitbit Blaze won’t connect to my phone and it is stuck on the time 9:35 but it is actually 7:42 so I am trying to sync it but it is just stuck on the “enter your number on tour display” I got my blaze in 2016 and it worked but then I tried to sync it and it is stuck ior somthing. Please HELP ME😉
02-15-2018 11:32
02-15-2018 11:32
Hi there @Holden-Schoone. Great to see you in the Fitbit Community Forums! 🙂
I'm sorry you're having problems with your Blaze not connecting 😕
I can recommend trying to restart your tracker and see if this makes any difference. You can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot.
If that doesn't make your tracker to sync, once you've restarted it, try to set it up as a new device. For this, go to the Account section at the top right corner on the Fitbit app and select the option that says "Set up a new device". Follow the on-screen instructions and once you're done, your tracker should be syncing without a problem.
Let me know if you need more help with this!
02-15-2018 12:54
02-15-2018 12:54
I’ve tried resetting the Blaze and setting up a new device but it’s still stuck after entering the code with connecting - which it never does.
