02-25-2016 16:21
02-25-2016 16:21
When I try to pair my Blaze with my phone (Samsung Galaxy NOTE 3), I get an error that says 'pairing rejected by blaze'. Blaze is set to 'pair' under 'bluetooth classic'
02-09-2018 14:35
02-09-2018 14:35
I finally got my Blaze to pair with my Samsung Note 8, but when I get to the gym and excited to have my notifications and music control on my wrist.... Didn't work. While at the gym I reset, restarted, paired twice and it NEVER worked. I get home and the pairing is disconnected again even after I'm in my house on WiFi for 20 min. Getting ready to send it back because it was too much money for a watch and heart rate monitor.
03-20-2018 15:55
03-20-2018 15:55
Hi,
I'm using a Galaxy S9 (plus), I'd much rather use the BLE (Blaze) signal for smart unlock as I don't have to have BT classic activate on my fitbit.
My S8 used the BLE without fault but the S9 simply says 'Bluetooth rejected by Blaze'.
03-20-2018 20:23
03-20-2018 20:23
As explained above @Wiltman you can not pair the tracker Bluetooth through the phones settings .You will get the rejected message every time.
You must setup the tracker using the Fitbit app, then the app will pair the tracker.
03-21-2018 11:51
03-21-2018 11:51
Now its paired but the watch stays in "connecting" mode.
03-21-2018 19:07
03-21-2018 19:07
@Ggnomind this being your first post in not sure what the history of the problem is.
Are you trying rotset the tracker up or just a sync?
What device is being used tgattyou see connecting on?
Did you let the Fitbit app pair the tracker or did you paorpit through the phones BT?
If you manually paired the tracker I would unpaid it .
04-21-2018 17:01
04-21-2018 17:01
I have owned and loved Fitbit for years. From my very first Fitbit Zip, One, Alta and Blaze. Until this last update. I have tried everything and it still wont work with my phone. I am so upset and aggravated . I have waited so much time trying to figure this out. And while writing this now my Blaze has gone black and nothing is happening.
04-21-2018 18:23
04-21-2018 18:23
@Carmenh423 this thread is about people using their phones Bluetooth to pair their device. I don't think you got the message "rejected by Blaze"
Saying that you tried everything tells us nothing about what was tried.
As for the Black screen, is the Blaze charged? And a restart was tired?
04-23-2018 00:49
04-23-2018 00:49
04-23-2018 07:09
04-23-2018 07:09
04-24-2018 16:28
04-24-2018 16:28
04-25-2018 07:57
04-25-2018 07:57
07-10-2018 21:43
07-10-2018 21:43
Same with my phone!
07-10-2018 22:01
07-10-2018 22:01
Pretty sure my Blaze is synced but I'm not receiving notifications at all. I've restarted my phone and the Blaze. I've uninstalled and reinstalled the apps. I've unpaired and re-paired the Blaze to the app. Still no notifications
08-27-2018 18:10
08-27-2018 18:10
I went in to the settings on my blaze classic and under the bluetooth classic it and on but if you switch it to pair and then press scan on your phone you'll get a passcode on both your phone and blaze which you then press ok and both and you should be all set
08-27-2018 19:03
08-27-2018 19:03
Hello @wenedwr if your getting the pair reject message,you are trying to pair the Blaze through the phones BT. This should fail. May I ask what phone you have,. Have you checked the Blaze to make sure that the DND is not turned on?
Do you get notifications on your phone nes lock screen?
Let's look at fitbits fitp site. There are things to check in both the phone's and the Fitbit aop's settings
Yes @Reo247 that is the way the pair the blaze classic, but please remember that the classic is only used for controlling the music on the phone. Notifications go through the Blaze low energy.
08-27-2018 21:12
08-27-2018 21:12
@Rich_Lauemy phone is a Samsung Galaxy 8+. I was told there have been issues pairing with this phone. My watch finally just started getting notifications one day, so it works now. I don't know why it works now but didn't then, but it does.
09-30-2018 12:17
09-30-2018 12:17
Thanks a ton. . .... It worked.
10-23-2018 04:13
10-23-2018 04:13
Thank you for posting your solution!!! For some unknown reason my "bluetooth classic" mode unpaired and stop using my phones GPS for my bike rides. Fitbit should add this to their instructions for new Blaze users.
10-23-2018 20:43
10-23-2018 20:43
10-25-2018 06:20
10-25-2018 06:20
The troubleshooting for receiving notifications doesn't work when Blaze (Classic) is the only way to sync to the phone. Ever since my Blaze totally died and I charged it fully (maybe a little too long) it took over a dozen times to finally get it to sync and it will only sync to the classic. I do not receive any notifications on my Blaze from my phone. There isn't an option in the settings on the app either. So the link you had attached does not work. How can I get notifications on my Fitbit again?
