02-25-2016 16:21
02-25-2016 16:21
When I try to pair my Blaze with my phone (Samsung Galaxy NOTE 3), I get an error that says 'pairing rejected by blaze'. Blaze is set to 'pair' under 'bluetooth classic'
12-10-2016 12:51
12-10-2016 12:51
@Rich_Laue Thanks for all the great advice you've given.
@mdeveau Welcome to the Community! As @Peer mentioned, this is a different procedure than syncing your Fitbit Blaze. So, in order to have everything properly set follow this procedure to have music control working properly.
Hope this helps!
12-20-2016 06:00
12-20-2016 06:00
This isnt working, when I attempt to pair through the app, I just get a "Not working?" screen then a Bluetooth Issues error, which ask me to either canel or restart bluetooth which, in turn give me the "Not working?" screen again.
Kinda aggrevating because
12-20-2016 08:37
12-20-2016 08:37
Using the fitbit app to replace the device worked for me as well. I tried everything to get the blaze to sync but going through app to add a device then choosing to replace the blaze again, I was finally able to get the app the recognize the blaze, it sent out a code and went into an update.
Fitbit seems to be very responsive to answering and responding to issues but any product should NOT be this difficult to setup. It should be plug and play. Very frustrating and I haven't even used it yet! It also seems like a very poor design that just plugging in the fitbit to the dongle doesn't initiate a charge.
12-20-2016 16:41
12-20-2016 16:41
It's nice to have you here @Alkentric! I would like you to make sure that you have the latest version of the app which is 2.39, it was just released on Thursday. If you do but your Blaze is still not syncing then please try this procedure.
@AlFB-Blaze Thanks for sharing what worked for you.
Hope this helps. Let me know how it goes!
12-23-2016 15:09
12-23-2016 15:09
Are you receiving notifications when you are connected to your phone with Bluetooth(Classic) mode?
12-23-2016 15:55
12-23-2016 15:55
12-23-2016 16:05
12-23-2016 16:05
12-23-2016 16:20
12-23-2016 16:20
Yeah, when Blaze is connected in the Classic mode, it won't show the notifications. To enable the notification, you have to go back to the device settings in the mobile app and enable the notifications.
Once the notifications are enabled, I see my blaze is no longer connected to my mobile phone in Bluetooth-classic(visibility) mode. But, the blaze is paired in Bluetooth mode.
Did you observe this behavior with your blaze and mobile phone?
12-28-2016 08:08
12-28-2016 08:08
this did not help. I truned my phone on and off, hit scan over and over and still not pairing 😞
12-28-2016 08:16
12-28-2016 08:16
Why @kiwash50 are you hitting scan, you can not pair your tracker to the phone. You connect the tracker to your account through the Fitbit app. Now that the tracker is connected to your fitbit account, the app will do the pairing.
Just make sure your tracker is not a connected device in your BT settings.
12-28-2016 08:43
12-28-2016 08:43
12-29-2016 22:39
12-29-2016 22:39
I I cannot pair through Bluetooth, my blaze to my s7 edge?
01-02-2017 07:43
01-02-2017 07:43
I am having issues with my devices as well. I am not able to pair or setup my new blaze. I already had a fitbit account so not sure as to why this is difficult. Resolition would be appreciated otherwise i will be returning to the store.
p.s. also tried to pair with my laptop. that too was not allowing me to do anything.
01-02-2017 10:58
01-02-2017 10:58
That is correct @Blaze91 you can not pair the device through the BT Settings, and this won't helo, you need to connect the Blaze to your Fitbit account through the fitbit app.. Once connected to your account the fitbit app will pair the tracker.
01-02-2017 11:06
01-02-2017 11:06
01-03-2017 06:53
01-03-2017 06:53
01-03-2017 06:56
01-03-2017 06:56
01-03-2017 07:26
01-03-2017 07:26
You opened the Fitbit app and used the 'Setup a Device' option on the 'Account' page?
What happened? (Your posts are quite vague so it's difficult to understand what you actually tried)
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
01-03-2017 11:02
01-03-2017 11:02
01-03-2017 16:44
01-03-2017 16:44
