02-25-2016 16:21
02-25-2016 16:21
When I try to pair my Blaze with my phone (Samsung Galaxy NOTE 3), I get an error that says 'pairing rejected by blaze'. Blaze is set to 'pair' under 'bluetooth classic'
09-15-2017 10:50
09-15-2017 10:50
Yep, you got it.
I've tried restarting both the app, my phone, and the Blaze itself. I also unpaired everything and then started from the beginning. None of the 10 times have worked. I uninstalled the app in hopes of this working, to no avail.
09-17-2017 03:15
09-17-2017 03:15
09-21-2017 10:25
09-21-2017 10:25
Thanks for the troubleshooting that you've done @Wardlee! Are you still experiencing this issue? Does this started happening when you update the app? Are you having any error? Did you tried this syncing troubleshoot?
Thanks for sharing the troubleshoot that worked for you @Forgot99! I'm sure this can help others in the Community. 🙂
09-23-2017 05:31
09-23-2017 05:31
That worked perfect for mine too mate. Thanks for that fix. On the other hand i can safely say Fitbit support is a bucket of **ahem**e. 2 hours on to them and in the end offered me a refund saying my device isnt compatible albeit the app from them says all my devices are compatibibe. They are a disgrace. Well done for that fix.
09-30-2017 07:43
09-30-2017 07:43
Thanks. Perfect you gave the solution. Now every is working fine..........
10-28-2017 01:04
10-28-2017 01:04
I have a slightly different problem. My Galaxy Note 3 stopped syncing to my Galaxy Blaze about a week ago. I turned my Bluetooth on my phone on and off and also restarted my phone. It made no difference. I was adviced to unpair the Bluetooth from my phone, so I unpaired both my classic and regular Bluetooth and then started again, but although I've marked to re-pair the classic Bluetooth the phone can't find the regular one and thus it still won't sync. What do I do?
@dawnierae wrote:
@SilviaFitbit wrote:@TLMDC A warm welcome to the Community! It's pretty weird that your notifications aren't staying set up. I would like you to make sure that you're not connecting any other Bluetooth device to your phone because that may be the reason why the notifications are unlinking.
If you're not using any other device, then please follow this troubleshoot.
@dawnierae Hey there! As mentioned in the above post, there's going to be interference if you're using two Bluetooth trackers. You can learn more about it by checking The Fitbit app for iOS is interfering with my other Bluetooth devices.
Let me know how it goes. Hope it helps.Yes, I'm aware of that, but a) I think it is a design flaw and b) that doesn't explain why I have to "re-boot" everything after being in my car to get the bluetooth working again. Just to do a test, though, I don't think the latter issue is related to my car, as I completely removed my car's bluetooth from my phone, and I still have the problem with the bluetooth classic pairing with my phone. It automatically connects to Blaze and won't forget it, no matter how many times I select "forget this device". The pairing for music control is a complete failure in my opinion, because it takes an unnecessarily long process to make it work. If I want to control music with my Fitbit, I have to start about 10 minutes before I actually leave to go on a walk so I can shut everything down, restart it, get the pairing to work, etc.
10-28-2017 08:14
10-28-2017 08:14
So I was having problems where it took an act of god to make my fitbit sync. I believe the problem is Bluetooth (Classic), which is really only used for music control. This solution worked for me
Step 1 - Use the fitbit app to disconnect your blaze from your account
Step 2 - manually go into your phone's bluetooth and "forget device" for blaze and blaze classic
Step 3 - On your blaze, turn off bluetooth classic via the settings menu
Step 4 - Using the fitbit app, reconnect (add device), and follow the steps to reconnect your blaze to your account
You will need to re-do all your other settings, notifications and alarms (through the app).
But now I'm getting notifications again and I've had zero trouble syncing my device since I reconnected. GPS even works again. I've even been away from my phone, and had my phone connected to other bluetooth devices, and when I re-open the app, fitbit connects right away, just like it used to.
The only downside so far is that you won't have music control anymore (that's the only thing that really uses bluetooth classic), which isn't a big deal for me. If I have bluetooth headphones on, I skip, pause, & hit play through other means anyway,
TL/DR - turn off bluetooth classic
10-28-2017 12:28
10-28-2017 12:28
10-28-2017 13:11
10-28-2017 13:11
@adrianb once the tracker is removed from the Bluetooth settings you will want to open the app and force a sync.
Just like when the tracker was setup everything is done through the app not the phones bluetooth. Your tracker does not have to be paired to sync.
10-28-2017 19:02
10-28-2017 19:02
10-28-2017 19:12 - edited 10-28-2017 19:13
No. You won't lose all your previous stats other than those that have not synced when you disconnect.
With my Surge what works is to power down my smartphone, then power it back up again. A couple of times I had to reset my Surge itself to get it to sync again.
10-28-2017 19:44 - edited 10-28-2017 19:45
Nope, your stats will be fine as of the last time it synced successfully.
Just remember to pair through your fitbit app and not your phone's bluetooth, otherwise it will continue to reject the pairing
10-28-2017 20:33
10-28-2017 20:33
You can log out of the app, but the phone is not connected to your account.
You can go into the phones Bluetooth and remove the tracker from the phone.. This should be done.
Removing the tracker from the app simply tells Fitbit that you don't want to use it anymore but will not remove the tracker from the phone.. It also will only add problems.. If the tracker can not communicate to sync, why will it communicate to pair???
Your data is only stored in your Fitbit account, not the phone, not the tracker.
10-29-2017 09:50
10-29-2017 09:50
I wasn't saying to remove the tracker permanently, I was saying remove and reconnect. The Fitbit pairs through the app, if you try to pair your fitbit using your phone's bluetooth, it rejects the connection.
I have found that removing all the fitbit bluetooth pairings and then starting over using the app to pair the fitbit, it solved most of the problems.
Basically, I used my phone's bluetooth to "forget device" for all fitbits, then i removed the tracker through the app, and then re-added it through the app, which paired the tracker to my phone's bluetooth automatically.
10-29-2017 09:59
10-29-2017 09:59
What I'm saying is that removing the tracker from the app is the same as removing the tracker from your account through fitbit.com.. It will not fix a sync issue, and could cause loss of any instances data.
Normally removing from the phones BT is enough to allow the sync to happen.
It is also not necessary to remove a device from your account to set it up again, simply use the add device and choose the replace option.
10-29-2017 10:17
10-29-2017 10:17
Well, where using the other options did not work for me, I had to remove it from my account completely and start over to get it to sync.
I tried replacing, I tried just removing the bluetooth, it took me actually removing it from my account and re-adding it. After I did this, my problems with syncing stopped.
10-29-2017 13:20
10-29-2017 13:20
10-29-2017 23:36
10-29-2017 23:36
10-30-2017 06:35
10-30-2017 06:35
This troubleshooting solution is offered on many of the forums, and it has not worked for me. I have also tried doing these steps in different orders, leaving out certain steps to let the tech automatically do it itself, and following these and other forum directions step by step... still no GPS connecting to my phone and still no notifications. I have tried every configuration (suggested throughout 10+ forums) of doing the notifications via the device, the phone, and the app, and no avail. I will not be recommending Fitbit to any friends or family, and I will certainly not be purchasing any more once this one becomes defunct. Every "update" that Fitbit comes out with does nothing, and I've even factory reset my phone to see if that solves the problem!
10-31-2017 10:41
10-31-2017 10:41
I was having the exact same problem. I shut down my blaze and started the bluetooth pairing from the beginning, having to get a pair code and everything, and this seemed to resolve the Bluetooth connectivity issue.
