01-25-2018 14:34
01-25-2018 14:34
My Fitbit blaze was low on charge this morning, I have charged it and it was fine. I've come to look at it this evening and it isn't on at all - when I plug it in to charge it it's saying it's fully charged. But when I take it out it goes straight off again. There is no green lights at the back they have gone off and won't come back on either. I have tried to reset it by using the left and right bottom buttons and still won't turn on. What is going on with it can someone please help me??
Best Answer01-26-2018 04:59
01-26-2018 04:59
It's great to welcome you @LeahNaomie.
Thanks for troubleshooting this by yourself. Since the restart process didn't work, I recommend keeping an eye on your inbox for further assistance.
Catch you later. ![]()
03-16-2018 19:32
03-16-2018 19:32
I am having the same issue and have tried the same things. No idea what to do now.
Best Answer03-17-2018 02:23
03-17-2018 02:23
I can’t switch on my blaze after I came out of the pool today. It started showing battery which also disappeared after some time. And i then put that to charge however not charging nor can be opened. Please help
04:16
10:00
03-19-2018
04:16
10:00
Hey @Drakos831 and @MPandey welcome to the Community, I appreciate the efforts in trying to fix this issue by yourselves.
@MPandey As you might know, the Blaze isn't a water resistant tracker, for more information take a look at the Can I swim or shower with my Fitbit device? article. If you have already swam with your tracker on, I recommend placing it in a bowl of rice, leave it there for 24 hours and then restart it.
@Drakos831 I recommend keeping an eye on your inbox for further instructions. In the meantime, check our warranty policy.
Keep me posted. ![]()
03-19-2018 19:32
03-19-2018 19:32
04-13-2018 13:50
04-13-2018 13:50
Same here. It's fully charged but when I take it out of the charging cradle, nothing. Per online chat this morning, I had to submit a very specific video via an upload link with a case number they had assigned me. I haven't heard anything since doing that about 5 or 6 hours ago.
Best Answer04-13-2018 14:47
04-13-2018 14:47
04:06
05:02
04-15-2018
04:06
05:02
Thanks for the update @Drakos831 and @MPandey. I am glad to hear that you will be receiving a replacement, at the moment of receiving it, you just need to do the following from your Fitbit app to set it up:
Now @Kjohnson2, welcome to the Forums. I would like to know if you have heard back from our support team, have they offer you a solution for this?
Hope to hear from you soon. ![]()
04-15-2018 04:50
04-15-2018 04:50
04-16-2018 10:25
04-16-2018 10:25
My Blaze will not turn on either. I tired the reset several times. The buttons don’t seem to do anything. Had it on the charger all night and still not responding to any reset.
10:33
04:08
AlejandraFitbit
04-16-2018
10:33
04:08
AlejandraFitbit
They are replacing mine. I'm sure you'll get the same offer. I've only had mine for 2 months though so I'm definitely leary of Fitbit now.
Moderator edit: Removed personal info
04:13
05:02
04-18-2018
04:13
05:02
It's great to hear that you will be receiving a replacement @Kjohnson2, you can follow the instructions provided in my previous post in order to paired the new unit.
Good to see you here @Equilon, as recommend previously, keep an eye on your inbox for further assistance.
04-24-2018 22:39
04-24-2018 22:39
i eventually got frustrated as no respite from fitbit. I then opened two screws myself n put that on charge overnight. Morning when i woke up i saw some light coming. I then configured that using App however the moment i took that out from charge, display vanished. I guess there is some problem with the battery. Unfortunately it’s not available in market 😐. Can anyone please help me with that? Thanks
Best Answer04-24-2018 22:51
04-24-2018 22:51
Same here, 3rd time in about a year - 1st time they replaced and now this morning is the 2nd time I’ve had to contact them with similar issues.
nothing back yet but they’re usually fairly speedy. Beginning to wonder if another brand will be more reliable.
04-25-2018 04:26
04-25-2018 04:26
Best Answer04-25-2018 05:32
04-25-2018 05:32
Best Answer11-16-2018 06:27
11-16-2018 06:27
My Fitbit Blaze will not turn on it was fully charged and the resetting is not turning it on. Any suggestions
Best Answer11-16-2018 16:32
11-16-2018 16:32
Best Answer02-27-2019 15:54
02-27-2019 15:54
I have tried everything that I have found online and in this community to try to get my Blaze to turn on, to reset. Nothing is working. It comes on when on charger, it’s fully charged, but when removed from cradle nothing, not even green lights
