05-05-2017 03:23
05-05-2017 03:23
Hi I had some problems with my Fitbit syncing with iphone
i have updated tracker as I knew There has Been issues!
but didn't work, so I disconnected it and now I can't re connect with my iPhone?
What should I do now as tried everything ??
05-05-2017 12:54
05-05-2017 12:54
It's great to have you here @Amyc6786! I appreciate the troubleshooting that you've tried in order to connect your tracker to your iPhone. In this case, I would like you to try this set up procedure. If after this, you're still not able to connect your Blaze to the Dashboard then follow these steps Why can't I set up my tracker?.
Hope this helps. Let me know the outcome.
