01-14-2017 18:57 - edited 01-14-2017 18:59
My fit bit wouldn't up date
i tried shutting it down
i tried restarting it
I tried turning my Bluetooth on and off
I tried removing it from the app and hen tried to add it again now now once I out the four digit code in it just won't connect it!
01-15-2017 10:54
01-15-2017 10:54
Removing it from the app will only remove it from your account, not the phone.
We still have to fix the no sync issue,
Lets first swipe to settings on tge Blaze then do a shutdown.
On the phone lers go to the Bluetooth settings and remove the Blaze from the phone.
Now power down the phone, and start it up.
Ok lets try to connect the Blaze back up to your account, then the app should pair the two devices.
Just a note, any unsynced data might be lost, but would not have if it was not removed from the account.
01-15-2017 12:58
01-15-2017 12:58
Website Forum is Buggy, Update is Buggy. Fitbit needs to put this on the Best Buy Display Rack before someone spends $250 on this crap. DO NOT RELEASE this crap to the public, I will never by FIT**ahem** again!
