07-30-2017 07:49 - edited 07-30-2017 07:54
The heart rate monitor on my blaze appears to be stuck at 70. Very high for me. I've gone for a run and it hasn't changed.
The green lights are working and I've reset my Fitbit. Nothing's changed. Can anyone help?
07-30-2017 07:56
07-30-2017 07:56
Hello @Ruth1el0u, have you tried a shutdown through the settings menu on the Blaze.. This does a true hard restart and requires a sync after turning back on.
The other thing many people have found that could help is to do 3 resets back to back of the tracker
07-30-2017 08:08 - edited 07-30-2017 08:10
No change Rich. But thanks for the suggestion. Any other ideas?
I've also noticed that my app isn't receiving any HR data
07-30-2017 08:13
07-30-2017 08:13
Have you tried turning the heart rate off/on? Tried in both auto and on mode?
07-30-2017 08:15 - edited 07-30-2017 09:23
Try setting the blaze up as a replacement to itself?
07-30-2017 08:31
07-30-2017 08:31
07-30-2017 09:26
07-30-2017 09:26
I assume you have. Also shit the heart rate off.
Have you tried a shutdown of the Blaze it tried setting the Blaze up as a replacement device yet?
07-30-2017 09:29
07-30-2017 09:29
07-30-2017 09:35
07-30-2017 09:35
No, and at most it could only affect the data on the tracker.. Anything before the last sync is already in the cloud server.
07-30-2017 10:04
07-30-2017 10:04
07-30-2017 12:35
07-30-2017 12:35
I'm happy for you @Ruth1el0u.
That was my next suggestion, I was simply stepping you through the steps they would be asking you to do.. This way when contacting fitbit you could get right to the point!
07-26-2019 17:58
07-26-2019 17:58
Whatnumber did you call to get help?
07-26-2019 20:09
07-26-2019 20:09
@Design06 in the top right is an icon where your avatar would be. Tap this, then tap contact Fitbit. Or simply Google it, or go to the help section in the Fitbit app.
