My water consumption has disappeared off my dashboard
ANSWERED
Like to log my water consumption daily and it has disappeared off my dashboard,I can only log it from the top right + menu,how can I get it back 😞
1 BEST ANSWER
Accepted Solutions
When you go to the Dashboard (computer), there is a circle with squares in it symbol in the upper left hand corner below the Fitbit logo.  If you click on it hopefully you will see to add the water tile to your dashboard.
On your phone, hit the "Edit" button and you should see water at the bottom without a check mark.  Add a check mark and it should appear.
1 REPLY 1
