Need help with Fitbit Blaze S/N (SOLVED! Don't mind this)
Hi guys,
I stopped using my Fitbit Blaze for 3 months, but then, the device was un-synced from my mobile device. First of all, is this possible without anyone else syncing on the fitbit device?
Second, Is there a way to check the S/N of a Fitbit device and match it to the S/N in the box?
Any help would be appreciated.
Thanks.
Solved this by contacting support and they helped me through this.
1 REPLY 1
It's great to welcome you @Kebo and to hear that your inconveniences are resolved. If you need anything else do not hesitate in posting it.
See you around. Woman Happy
