Need help with syncing
My blaze used to work well, but ever since they came out with the ionic, it has had A LOT of trouble syncing and problems with losing charge twice as fast.
Also, why was there not a real update for the blaze? I want to be able to finally choose a good watch face for my blaze, even if that means making it myself. But if course this is only available on the ionic.
4 REPLIES 4
Hi
Are the Blaze issues fixed?
Regarding the watch faces for the Blaze, from amigo @JonFitbit in this thread
'Fitbit Ionic is the first device which uses Fitbit OS. Unfortunately, previous generation devices are not supported.
Hi, thanks for your concern, but no they're not.
And for the clock faces, I'm not even asking for the new fitbit os on the blaze, just an update to the existing one so I can add different watch face designs. Why is it that a pebble watch that costs like half of a blaze can do this but the blaze can't? So much for fitbit's purchase of pebble as a way for them "to learn."
Because the Blaze does what the developers designed it to do, but not what you want it to do does not mean that it is broken or that it needs to be fixed.. The Blaze was never advertised as having the ability for user created watch faves.
As for the Pebble why is it that the company does not make any more trsckers?
This is also strange to me that blaze with beautiful full color display has such small database of clock watches. For me only one is acceptable all this years, thats so sad.
