04-03-2016 14:20
04-03-2016 14:20
Fitbit Blaze arrived without the dollup, so I used a dollup from a previous fitbit to try and set up the device. It dropped me about a half dozen times at various points of trying to go through the setup routine. So far the Blaze is a total bust for me. Rather than wasting my time with a long string of messages, what is you phone number for a knowledgeable, warm body? Also, does it matter what generation of dollup I use?
Best Answer04-03-2016 14:24
04-03-2016 14:24
04-05-2016 06:23
04-05-2016 06:23
Welcome to the Fitbit Community @PSDiver! 🙂 when you mention a dollup do you mean the USB Dongle? If you are referring to the Dongle used to sync the tracker to your computer, the Blaze doesn't include a Dongle as it should sync with the charging cradle, also Fitbit Dongle will work with the tracker if required during the set up process. Did you reach out to support? @Rich_Laue thanks for your cooperation 🙂
Keep me posted.
It is health that is real wealth and not pieces of silver and gold! Share your story!
