07-12-2017 01:56
07-12-2017 01:56
Pls help me have shut down my blaze from setting to aply scratch guard and now am not able to turn on. Wht should i do please help
05:32
06:34
07-12-2017
05:32
06:34
Hey there @Rohi1234! Welcome to the Community Forums! 🙂
I'm sorry you're having problems turning your tracker back on. For this you will need to press and hold the button on the left for about three seconds until it comes back on. If this doesn't work, make sure that your tracker is charged and after that, you can try to restart it. You can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot and turn back on.
Hope this helps. Let me know if you need more help with this!
07-12-2017 05:36
07-12-2017 05:36
Best Answer07-12-2017 05:46
07-12-2017 05:47
01-24-2019 00:55
01-24-2019 00:55
Hello sir after using blaze for more than year having facing lot of issues regarding steps .For example my steps is 7235 is done then it gets stuck with same figure while continues walk aftr some Tym it works fine but again it Wil hang did restart n all done very thing still am facing issues .please help me
