05-23-2016 15:46
05-23-2016 15:46
So I got the Blaze and have had it for almost a week. I switch off between my HR and the Blaze. Today I decided to do a test. I wore the Blaze all day, on my left wrist, which is my "watch wrist". It tracked my steps just fine. I decided to keep it on when I took my dogs for a walk. Usually, I will wear my HD and that will be on my right wrist. (yes I do take one off and do not wear both at the same time)
So the leashes and dogs are on my left side where I am holding the leashes. My right hand is free. Well, got back from 1/2 hour walk, and the Blaze did not track my walk. This is very concerning to me. Is it because the Blaze is not on my "swinging arm"?
I had to mannually enter my walk in.
I also did the eliptical with the Blaze on, before my walk, and it did track it just fine.
Any suggestions would be great!
05-24-2016 08:00 - edited 05-24-2016 08:00
@Stacesam1 wrote:So I got the Blaze and have had it for almost a week. I switch off between my HR and the Blaze. Today I decided to do a test. I wore the Blaze all day, on my left wrist, which is my "watch wrist". It tracked my steps just fine. I decided to keep it on when I took my dogs for a walk. Usually, I will wear my HD and that will be on my right wrist. (yes I do take one off and do not wear both at the same time)
@Stacesam1From my understanding of how it works, it does track steps largely based on the typical movements of a person running and walking (moving their arms in a certain way). Check this article out, which explains a bit further.
Hope that helps!
05-24-2016 12:41
05-24-2016 12:41
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
05-24-2016 14:38 - edited 05-24-2016 14:43
Just a note there are 4 ways to track walks with the Blaze.
Personally I prefer to start manually since there is better control, and unhooking always shows up as an elliptical because of the arm motions.
05-24-2016 17:33
05-24-2016 17:33
