03-12-2017 08:30
03-12-2017 08:30
I have had a Blaze since December 2016. I wondered if there is a way I can see my real time per mile so I know where I need to speed up in my training. ?? I have used other technologies that track mile per mile times,but haven't seen anything on my blaze other than my whole workout time.. Is this not a fitbit feature? Thanks!
Best Answer03-12-2017 09:01
03-12-2017 09:01
Workout - Running
There is a gear where you can tap on. Then you can choose what is shown. For example pace (min/km).
Best Answer03-12-2017 11:50
03-12-2017 11:50
Right. I have that set. What im looking for is the Lap info after you click done. That is the info I need to find.
Best Answer03-12-2017 11:55
03-12-2017 11:55
Are you looking to see it on the tracker or the app?
Here is the app of a previous walk of mine.
03-12-2017 11:55
I think you can set that too. I don't use that, I only marked laps manually.
Best Answer03-12-2017 20:13
03-12-2017 20:13
I looked on both as well as the non mobile version. Mine doesn't have splits as an option. Is that a setting? That is exactly what im looking for!
03-12-2017 22:34
03-12-2017 22:34
I don't see a setting for this, I used walk either GPS but not sure what tracker. I've checked my other s and they all have splits if they have total miles.
On the website I see a map with a chart in the corner.
I did notice that I only get splits when using the connected GPS.
03-13-2017 06:00
03-13-2017 06:00
Maybe thats my problem. I do alot of country running where there is no GPS. I will do my run in town today and see if it gives me that option. THANK YOU very much!
Best Answer03-13-2017 06:07
03-13-2017 06:07
No GPS in country? I expect more problems in town, due to high buildings.
Best Answer03-13-2017 06:57
03-13-2017 06:57
@Tbrab000Welcome. I get splits on Connected GPS for both walking and running. Fortunately I have a very strong 4GX Android phone signal and no dropouts as you can see from the image and I'm metric. The pace was just below Fitbit's "Very Brisk Pace" for walking, 6 kmh, or 3.7 mph.
If you are having GPS issues via your mobile, especially in the country, I use MapMyRun and GPS Status Apps to ensure the phone is communicating correctly before I worry about the Blaze.
