08-31-2017
10:40
20:14
DavideFitbit
08-31-2017
10:40
20:14
DavideFitbit
Again hello to the Blaze family and for those who come in later after this posts. I understand the frustration that you that you be going through. This is a journey being a greenhorn with this watch in which I had the Charge 2 and the Samsung Getfit 2.
Found out not fully comparable with the SE phone even though it was advertised it was. When getting the Blaze had problem with battery; after two days drain to medium. Contacted Fitbit after finding out from Best Buy telling me that did not know if they would be re supplied for me to do an exchange. Question to all of you heard either the Surge was replaced by the Blaze in which the Surge will be obsolete?
08-31-2017 10:42
08-31-2017 10:42
Make this correction the Samsung was fully compatible with the IPhone SE.
08-31-2017 10:43
08-31-2017 10:43
Samsung not fully comparable
with the IPhone
08-31-2017 11:25
08-31-2017 11:25
@KraKree i doubt the Blaze will replace the Surge, this would have happened a year ago. The Blaze is a step down from the Surge, it is more likely that the Ionic will repla e it.
